String gauges on OM http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=4493 |
Author: | L. Presnall [ Thu Jan 12, 2006 7:20 am ] |
Post subject: | |
Okay all you engineer types out there...I'm appealing to your wisdom...I want just a touch more neck relief in an OM I built a while back...the one where the truss rod nut was broken off ![]() |
Author: | John How [ Thu Jan 12, 2006 8:12 am ] |
Post subject: | |
Only you would know how you braced it but there should be no reason you couldn't use mediums on an OM. |
Author: | L. Presnall [ Thu Jan 12, 2006 8:24 am ] |
Post subject: | |
Hesh, those are the VERY strings I bought to put on there depending on the advice I got here... ![]() John, yep it's run-of-the-mill bracing for an OM right to the Martin plan...LMI white tho.. ![]() Thanks guys! |
Author: | John How [ Thu Jan 12, 2006 8:33 am ] |
Post subject: | |
I've use that glue on the last 15 or so builds without so much as a hint of trouble. |
Author: | Josh H [ Thu Jan 12, 2006 9:02 am ] |
Post subject: | |
I think you should be fine. GHS makes a True medium gauge which is a bit heavier than lights. Or the D'add bluegrass set that was already mentioned. I would try those first and see if that helps. Josh |
Author: | burbank [ Thu Jan 12, 2006 10:48 am ] |
Post subject: | |
Larry, I wonder if, after some period of time under the extra pull of the mediums, the neck would take enough of a set that you could go back to your usual strings. Possibility? Pat |
